6-Speed Carib box notchy
Postby petercad » Sun Apr 20, 2008 6:55 pm
Got a 6-speed Carib, and notice that the box is notchy and hard to shift when cold. What is the recommended fluid for it and is there another alternative that I can use for hard shifting when cold?
2006 Fielder S, CVT, and immaculate.....
petercad
Postby gepsk8 » Sun Apr 20, 2008 9:11 pm
auto trans fluid (atf) for 1000-2000k's helps then back to good quality manual stuff (redline)
O272754663
gepsk8
Postby petercad » Wed Apr 23, 2008 7:33 am
Cheers for that. Will try it this weekend. What is the redline stuff - just a 75w/90 manual trans oil?
petercad
Postby escortman » Wed Apr 23, 2008 8:03 am
just use a good weight engine oil
4x4 toyota blizzard offroader
escortman
Postby barryogen » Wed Apr 23, 2008 9:35 am
from taking two or three for a spin, the 6spd seemed to be a lot notchier than the 5 spd... not sure if they had just been abused/mis-used or not, but the 6 spd manual in my old runx was far notchier than the 5 spd in the normal corolla
barryogen
2ZZ Guru in training
Postby petercad » Sat Apr 26, 2008 7:22 pm
Yep, I agree, the 5-speeds are smoother. Just that this one seems worse than the other 6-speed I had 2 years ago with similar k's on it. What weight engine oil do you suggest, or just any one that is good quality.
petercad
Postby Mr Revhead » Sun Apr 27, 2008 10:45 am
engine oil? not what id use....
Postby Dell'Orto » Sun Apr 27, 2008 1:25 pm
Would be far too thin! What does the factory recommend, 75w90 or something? Plus engine oils aren't EP rated.
Postby petercad » Sun Apr 27, 2008 5:49 pm
It has Penrite 75w90 in it now and its a little better. Still not as I remember them though. Whats the actual recommended lube for them?
petercad
Postby method » Sun Apr 27, 2008 6:04 pm
Try the redline oil
It actually makes a difference over other oils!
PICS UPDATED DAILY
method
