Electrical problem in my starlet
Postby gt-ep82 » Sun Apr 20, 2008 9:27 pm
hi, ive searched this forum back to front for days now but havn't found an answer to my problem.
Recently my alternator gave up the ghost at the same time all my electrics stopped (windows, rev counter, temp gauge, petrol gauge) also the motor runs real sluggish. I replaced the alternator and gave the battery a full charge, turnt the key on but still no electrics, no dash lights. I can turn the motor over, and i've tested the battery with a multi-meter, turnt off getting 12.0v, when car is running im getting 12.4v. Ive checked fuses in the car and in the engine bay. I was told that maybe the alternator light on the dash might be blown causing the alternator to not work??? As i'm getting no dash lights before start up, i'm not sure if it's the alternator again maybe something in the circuit??
I have a EP82 starlet with a 4efte motor.
Help would be appreciated. thanks 8)
gt-ep82
Postby 1hypo3 » Sun Apr 20, 2008 9:59 pm
i would check the main alternator fuse again- do a continuity test on the fuse
1hypo3
Postby Stu- » Sun Apr 20, 2008 10:10 pm
You should be getting near 14v when chargin. 12.4 tells me something isn't right with the charge circuit or the alternator.
Project Thread
Stu-
Postby gt-ep82 » Sun Apr 20, 2008 10:33 pm
Thanks will check it again tomorrow, and going to put in new earth.
gt-ep82
Postby matt dunn » Sun Apr 20, 2008 11:09 pm
how much voltage is on the big heavy wire to the B+ terminal on the alternator with the car switched off.
12. something is ok,
0V is a blown main fuse 80/100A.
Postby gt-ep82 » Sun Apr 20, 2008 11:35 pm
12.4v if I remember right
gt-ep82
Postby matt dunn » Mon Apr 21, 2008 12:19 am
gt-ep82 wrote:12.4v if I remember right
If that is the case then check the under dash fuses,
look for one labelled IGN or EFI or Gauge,
but just check them all.
Postby gt-ep82 » Mon Apr 21, 2008 5:48 pm
Thanks everyone,
Replaced 2 fuses today, put new earths in and got my electrics back :lol:
efi relay under bonnet looks a little burnt, so will be replacing that one aswell
gt-ep82
