Sharing Vacume lines?
Postby RedMist » Fri Apr 25, 2008 6:00 pm
Just plumbing up the new car and wondered which of the two below I can share a vacume line with (as I'm out of vacume barbs on the plenum)
Boost Gauge
FPR
Two blow off valves
Boost Control Solinoid
MAP
Or should I cut through my shiny plated plenum and create another vacume port?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Burning Angel » Fri Apr 25, 2008 6:21 pm
you can share all exept the MAP as that should be run by itself.
FPR and boost gauge would be my pick.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby method » Fri Apr 25, 2008 6:42 pm
I would go BOV and Boost Gauge
As FPR is kind of important too.
Usually MAP and FPR on individual lines.
PICS UPDATED DAILY
method
Postby matt dunn » Fri Apr 25, 2008 7:26 pm
IMO, the pressure for the boost control solenoid should not be plenium feed,
the feed for that should be from before the throttle,
otherwise at part throttle, the turbo can build up way past boost pressure in the intake track, but there is still not enough pressure to open the wastegate as manifold pressure is still low.
Postby escortman » Fri Apr 25, 2008 9:05 pm
i reckon best place for boost controller line is straight off the turbo, so cant over spool the turbo and if u have a ebc with boost readout can tell if u have a leak etc
4x4 toyota blizzard offroader
escortman
Postby ChaosAD » Sun Apr 27, 2008 11:29 am
If you have an electronic boost controller such as a profec you will still need to plumb the unit into the plenum and the solenoid into the compressor cover
ChaosAD
Postby matt dunn » Sun Apr 27, 2008 12:16 pm
ChaosAD wrote:If you have an electronic boost controller such as a profec you will still need to plumb the unit into the plenum and the solenoid into the compressor cover
Ah, yes you are right, forgot about that type.
Postby RedMist » Sun Apr 27, 2008 8:43 pm
NZEFI supplied a MAC valve. Its only a three port valve, atmosphere, wastegate actuator, turbo compressor outlet.
We placed an additional fitting in the first intercooler plumbing tube.
Cheers Gentlemen. Should be on NZEFI's dyno tomorrow.
RedMist
Postby matt dunn » Sun Apr 27, 2008 8:54 pm
So i take it you are using the link to control the boost solenoid.
Will be interested in hearing how that goes with the new G3's as I am also looking at changing to that way of doing boost control.
