silvertop wiring help
Postby gleem » Sun Apr 27, 2008 9:54 pm
g'day all ive got a 4age silvertop 20v all bolted in to my ae82 fxgt, have a silvertop loom, fusebox etc.. ive never done any wiring work before so a little bit puzzled where to start, does anyone here have any hints / tips? also does any one know of any good website with info on this sort of thing? i take it i will need a wiring diagram as well, does anyone on here have one of these?
gleem
Postby gleem » Sun Apr 27, 2008 10:00 pm
also prepared to pay cashies for people that may be interested, im in north shore auckland
gleem
Postby 20v_rollaboy » Sun Apr 27, 2008 10:29 pm
Some helpful stuff here, including diagrams and pin-outs.
http://club4ag.com/
20v_rollaboy
Postby ChaosAD » Mon Apr 28, 2008 7:24 pm
im doing the same thing but using an aftermarket ecu.
Ive kept the standard fusebox etc and am using the stock loom.
Have removed the wires that go between the bluetop and ecu and fitted the wires out of the silvertop loom that go between the silvertop and ecu.
You will want to use the starter solenoid out of the silvertop loom.
The injector power feed for the bluetop is behind the drivers headlight.
The fuel pump wire goes to the bluetop ecu, this will need to be run to the afm.
If you pull the covers off both the ecu's you will see each pin has a label such as Fc ( fuel pump), E1-E02 (earths) etc.
The ae82 wiring diagram on club4ag is a bit off as its for the usa version. The silvertop one seems correct.
ChaosAD
