are there any CoilOnPlug coils to fit silvertop
Postby ChaosAD » Wed Apr 30, 2008 11:04 am
Looking into running a coil on plug setup on a silvertop.
Does anyone know of a set of coils from another car that will fit the silvertop.
ChaosAD
Postby Py7h0n » Wed Apr 30, 2008 1:33 pm
Dunno how far off they would be but I used Honda bike ones on a few engines.
Py7h0n
Postby matt dunn » Wed Apr 30, 2008 9:59 pm
from what I looked into i think toyota 1NZ of 1SZ or similar, toyota echo type one's, could be modified to fit.
Postby ChaosAD » Thu May 01, 2008 8:15 pm
do you remember what needed modifying?
The echo's still fairly new so may be hard to track some of them down.
ChaosAD
Postby Zak » Thu May 01, 2008 9:47 pm
I have a set of 1NZ-FE, 1AZ-FE and 1ZZ-FE ones at work, have yet to try them on my silver top though, I'll try to remember to check on the weekend.
Zak
Postby ChaosAD » Fri May 02, 2008 7:23 pm
Considering the heat issues with coilOnPlug setups and the minimal benefits I think ill just go with a pair of mitsi wasted spark coils.
Ive read you can just use generic leads when going with wasted spark coils, does it matter not having the tube on it? just wondering about the leads wearing where they come out of the tubes in the head
ChaosAD
Postby Zak » Fri May 02, 2008 7:48 pm
Mine haven't worn, they are just generic ones. been like that for about 15 - 20,000km so far with out trouble.
Zak
Postby frost » Fri May 02, 2008 11:08 pm
if your using the 4g63 coils then you can use the leads too, just cut some of the rubber boot off the top to fit, i have evo8 leads on my blacktop,
