ke35 lsd
ke35 lsd
Postby mint ke35 » Sat May 10, 2008 1:03 pm
Hey i need help
What lsd rear end is easiest to fit in a ke35
mint ke35
Postby Mr Revhead » Sat May 10, 2008 1:08 pm
ae86 springs to mind, but really anything with the right width can be made to fit. early RX7?
dont think there is anything out there that will be less than a grand to get sorted as i cant think of anything off hand that will bolt straight in. unless you manage to find a diff already modded to suit
Postby Dell'Orto » Sat May 10, 2008 1:10 pm
A TRD U code LSD will be the easiest to fit, also probably the most difficult to find!
Postby johntramp » Sat May 10, 2008 5:21 pm
doesn't a ke35 have leaf springs? wouldn't a hilux diff be easier then?
johntramp
Postby Mr Revhead » Sat May 10, 2008 5:37 pm
hilux would need a lot of mods such as shortening, and they arnt a real LSD anyway
Postby fangsport » Sun May 11, 2008 3:47 pm
mitsi L200 are usually quite cheap.
they are leaf sprung but would need FWD offset wheels to tuck inside guards.
fangsport
Postby ps165 » Mon May 12, 2008 12:37 am
ive gota ae86 disc brake rear end in chch forsale, depends if you want to upgrade for disc brake aswell as lsd, a cheap option would be t series drum out of a corona or something similar for under a hundred bucks, and a trd lsd or standard 86 lsd. i can supply trd lsd, pm for more detail.
ps165
Postby Mr Revhead » Mon May 12, 2008 12:38 am
make sure you get a late diff
the early AE86 TRD one is no longer made
Postby mint ke35 » Thu May 15, 2008 6:41 pm
It doesn't need to be leaf sprung though because I'm engineering some custom parts to get rid of the leafs and replace them with coil overs.
mint ke35
Postby ke25sr » Wed Jun 11, 2008 1:38 pm
ps165 wrote:ive gota ae86 disc brake rear end in chch forsale, depends if you want to upgrade for disc brake aswell as lsd, a cheap option would be t series drum out of a corona or something similar for under a hundred bucks, and a trd lsd or standard 86 lsd. i can supply trd lsd, pm for more detail.
i'm still waiting for my LSD and you wont txt back or reply to PM's?
ke25sr
