Mr Revhead wrote:fans working?
gauge sensor working?
Bazda wrote:is the fan sucking the right way ?
Truenotch wrote:What was happening with mine was what seemed like an air lock that wouldn't go away, and it would have a regular burp when bleeding (even after hours). The 2nd symptom was that the water kept being sucked away from the heater core bleeder, which was really confusing.
It turned out to be pitting between the no4 cylinder and the water gallery that feeds the heater.
Did you check the block before doing the gasket? And what gasket are you running?
rollaholic wrote:when you say the radiator is three months old, do you mean it was second hand 3 months ago, was reco'd three months ago, or was brand new 3 months ago?
