2C engine bellhousing
Postby Lloyd » Wed May 14, 2008 7:27 pm
Alright, want to clear this up for once. Do the 2C engine gearboxes bolt up to S series engines? And if so does the engine sit on the original angle or does it stand them up?
Postby strx7 » Wed May 14, 2008 7:51 pm
yes they are the SAME engine bolt pattern.
Need to mill 10mm apprx off the front face to get the input shaft to meet up with the pilot bearing.
Postby KinLoud » Fri May 16, 2008 12:07 am
Yes - I am running a C bellhousing behind my 3sge in my carina.
Search for some past posts of mine in regards to how I solved the input shaft vs pilot bearing.
You don't "need" to shave 10mm of the bell but it probably makes it less fiddly for solving other related problems like clutch release...
Ken
Ham
021 408 863
Postby .:O4AGTZ:. » Sun May 18, 2008 12:15 am
yea should bolt up no probs as long as you mill a bit off the front face
.:O4AGTZ:.
Users browsing this forum: Bing [Bot] and 6 guests
