It doesn't run rich now. great.
But the ignition timing was very low at hot idle it was as low as 6 degrees.
so we earthed out the diagnostic plug and tuned the dizzy.
i was told to give it 16 drgrees. no the hot idle is about 2500 rpm.
I have cleaned the throttles since and screwed in the bleed screw but there no hard in and still idles high.
What else controls the idle speed on the black top?
