another n00b question to do with 4a cas
Postby method » Thu May 29, 2008 2:34 pm
On a 4agze if you turn the cas clockwise does it advance or retard the timing?
PICS UPDATED DAILY
method
Postby method » Fri May 30, 2008 12:51 pm
Someone must know!?
PICS UPDATED DAILY
method
Postby IH8TEC » Fri May 30, 2008 1:52 pm
retard is clockwise
advance is anti clockwise
Postby RomanV » Fri May 30, 2008 2:53 pm
Well yeah... Which way does the engine rotate? Turning the CAS the opposite way to this will 'advance' when it sees the signal for it.
Postby method » Mon Jun 02, 2008 12:11 pm
Thanks
Yeah i should have thought a bout it, im sick of thinking haha!
Was gunna rangi bump back timing at the drags because i have a bad flatspot around 6k. Base timing is at 13* advance and im sure the knock sensor is picking up a little knock around there.
PICS UPDATED DAILY
method
Postby 85AW20v » Mon Jun 02, 2008 11:04 pm
Also check your cam timing. I've just had the same sort of thing on a twincam Mazda and it turns out the cam timing was out by a tooth so then the ignition timing couldn't be adjusted correctly.
See ya
Simon
85 MR2 20v
85AW20v
