Swapping G series diff ratio in 92 LN130 surf
Postby AE85.6 » Thu May 29, 2008 10:02 pm
Tried doing a search but didn't find anything relevent.
I know not the normal ride with a g series lsd that is posted about but here goes,
92 LN130 hilux surf.
Has a diff code G145 which according to this site http://ourworld.compuserve.com/homepage ... o/diff.htm
is a 4.875 ratio !?!
Basically when doing 100kph it revs at 3000.....doesn't sound like much I know but when your car only revs to 4ish it slurps gas and sounds like it is going to explode so I thought maybe change diff ratio ?
just wanna know what beasts have a smaller ratio g series lsd diff that I could swap with or at least steal crown and pinion from ?
Or advice from anyone that has already changed ratio.
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby postfach » Thu May 29, 2008 10:09 pm
you can get them from *a70 supras, *z20 soarers, I think your best bet is something like a non turbo, auto GA70, pretty sure those come with a 4.6, otherwise you go down to 3.7, 3.9 and 4.1, which may be too extreme
postfach
Postby AE85.6 » Thu May 29, 2008 10:41 pm
hehe sounds extreme now as is !
just want it to not work so hard when on the motorway.
maybe 4.1 ?
Im not worried about it accelerating a lil slower as its a diesel surf so its slow anyway and offroad there is still low ratio and all.
AE85.6
Postby d1 mule » Fri May 30, 2008 12:21 am
both my LN61 and JZX81 have G282 4.3:1
and that pulls like 2800 rpm with 31" itres at 100kph, sucks the fat one really, go for like a 3.9 or 4.1
remember ya will need front and rear
d1 mule
Postby mjrstar » Fri May 30, 2008 9:47 am
i have a spare 4.3 ratio open diff head for sale if you are keen. (rear only)
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby strx7 » Fri May 30, 2008 2:08 pm
is it manual or auto?
my LN130 Auto came with 4.55:1, manuals are usually 4.3:1
The LN130 5th gear is higher(more revs) than the VZN and KZN130 5 speed box.
I have a VZN130 5 speed in behind my 2JZ and I put 4.1's in it, with 31 inch tyres i'm pulling 2200rpm at 100kph. Personally i think a LN130 would be struggling trying to pull those revs on the open road. it'd probably do it, but any incline or a trailer would halt progress.............
