97 Curren Front Right Tyre Rub
Postby callum_62 » Fri May 30, 2008 2:31 pm
Hi Guys,
Just noticed a real strange kind of crunching sound coming from my front right tyre on 97 Curren.
Had the car 2 years and the noise just appeared.
Had a look, and seems the tyre is rubbing on the guard....this only happens when im full lock right and REVERSING!
Tyre size is...205/55/R16....been told the tyre is 'too tall' hence the rubbing.....questions would be, why is this just happened now, and could I change the height of the tyres without changing rims?
This second hand tyre has been on there for well over 6 months....
Thanks
callum_62
Postby Dell'Orto » Fri May 30, 2008 3:10 pm
Check your strut, it might be stuffed. Does it have stock springs or lowered ones?
Postby callum_62 » Fri May 30, 2008 6:40 pm
Hi,
No, everything on the car is stock I think.
I had it into Toyota/Firestone today, and he had said its simply the tyre is too tall...but if its too tall, then it shouldve always been too tall and always rubbed, surely??
callum_62
Postby Dell'Orto » Fri May 30, 2008 6:43 pm
Yep, always should have rubbed, tyres wear smaller not larger :lol:
See if your strut is leaking, it might be knackered and have drooped enough to rub now.
Postby callum_62 » Fri May 30, 2008 7:14 pm
thanks for the advice....other question would be, why only when reversing full lock right?
no noises at all when driving forward, even on full lock?
callum_62
Postby 85AW20v » Fri May 30, 2008 10:43 pm
Lower arm and/or swaybar bushes could be stuffed as well allowing the strut to move but only under certain loads and angles. Time to have those nolathane bushes fitted :D
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: Bing [Bot] and 11 guests
