auto ecu
auto ecu
Postby IKE86 » Sat May 31, 2008 4:37 pm
I got a wrecked ae92 today andsadly its auto just wondering will the loom and ecu be compatible with my manual ae85. And any advice on wiring it up will be much appreciated.
IKE86
Postby Mr Revhead » Sat May 31, 2008 6:04 pm
yes can work no problem, do a search and you will find this has been covered a few times :wink:
Postby IKE86 » Sat May 31, 2008 6:39 pm
thanks thats a relief. did search but i admit my searching skills are not the best
IKE86
Postby Mr Revhead » Sat May 31, 2008 6:48 pm
ok
theres been a few threads lately on how to make an auto ecu work in a manual conversion
that is applicable to your situation.
just to clarify, i didnt mean that it will be a straight plug in etc... you will need to do wiring.
but you will be able to use the ae92 ecu and loom, albeit with some mods to the loom
Postby IKE86 » Sat May 31, 2008 7:31 pm
[quote="Mr Revhead"]ok
could you please point me in the right direction of these threads so that i can do some research?
IKE86
Postby Mr Revhead » Sat May 31, 2008 7:50 pm
try this one
http://forums.toyspeed.org.nz/viewtopic.php?t=65987
note thats for an ae101, pricinple is the same but the wires MAY be different... but tells you what to look for
Postby IKE86 » Sat May 31, 2008 11:21 pm
cheers mate youve been a huge help
IKE86
