4agze twincharging?
4agze twincharging?
Postby h8wrxs » Wed Jun 04, 2008 1:37 am
gday
random question
ive seen pictures of twincharged 4agze's on the net and id quite like to build one
so hypothetically say i got a 4agze engine, stripped it down rebuilt head to toe with all new forged pistons and rods etc adn set up the sc12 supercharger on the back and everything, but bolted on a turbo on the side, is there any reason it wouldnt work?
and if i did would it matter if the turbo ran higher boost then the supercharger?
h8wrxs
Postby Lloyd » Wed Jun 04, 2008 8:22 am
Most kits/setups are with one blower feeding into the other. Depends if you want to go that way or have them both feeding into a common intercooler separately, in which case you'll need to work out how to switch between them nicely. Good thing with the SC12 is the electric clutch on so you can simply turn it off when not needed
Postby tsoob » Wed Jun 04, 2008 11:00 am
its far easier just to turbo tho....
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby barryogen » Wed Jun 04, 2008 11:09 am
Most of my reading on twin charging got to a point that said go "filter, turbo, SC, IC, TB, engine" for ease of use.
They almost all said chose a turbo that seems massive, and a supercharger that seems small.
All said avoid the Toyota SCs.
The SCs off the mini(Eaton M45 or MP45 from memory) seemed to be a common choice up to 2L engines.
Matt Dunn has played with twin charging, and had something like 30psi of boost at idle... I'd imagine it would make it almost undrivable.
barryogen
2ZZ Guru in training
Postby Crampy » Wed Jun 04, 2008 12:58 pm
Twincharger setup for the VW Twincharged TSI engine.
From memory it won engine of the year a year or two ago.
Not made for outright horsepower, but make a small displacement engine have a very broad torque curve and make good decent power right through the rev range, which cannot normally be achieved. You normally have to sacrifice power at one end of the rev range to make more power at the other.
The bypass valve is for when the turbo starts using more air than the positive displacement supercharger can provide. It opens allowing more air through and hence the turbo will boost higher than the S/C was. The Toyota S/Cs would be good for this, as you could declutch them once the turbo takes over the boost producing role.
It makes for a very complex intake and will cost a lot of money to setup get tuned correctly. But I suppose if you are willing to get it up and running, the torque delivery would be amazing.
Crampy
Postby tsoob » Wed Jun 04, 2008 1:26 pm
this setup up using a PWR water to air cooler would create the most awesome street driven weapon
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Crampy » Wed Jun 04, 2008 1:34 pm
tsoob wrote:this setup up using a PWR water to air cooler would create the most awesome street driven weapon
Yes, yes it would.
I'd say it'd be a bit of a waste of time in a FWD though, as it'd just be spin spin spin everywhere.
Crampy
Postby FXGTV » Wed Jun 04, 2008 2:56 pm
If i remember right there was a god awful ae92 fxgt with a huge kit, crazy paint job, and a twin charged 4age. last i heard the engine blew and its just running thr turbo now :P
1988 r31 TI Skyline.
FXGTV
Postby tsoob » Wed Jun 04, 2008 3:30 pm
FXGTV wrote:If i remember right there was a god awful ae92 fxgt with a huge kit, crazy paint job, and a twin charged 4age. last i heard the engine blew and its just running thr turbo now :P
there has been a few of these, about 4 years ago there was a really nice one made in australia it was red 4 door, if any one has any pics post them up it was mint.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby JustinSpiderholden » Wed Jun 04, 2008 3:35 pm
Ah I have got the hot4s magazine with this car on the cover, had the plates 4pervn or somthing
Was running a 4agze, with twincharging, guy had put alot of thought into the built and was extremley cool, I loved the twin air filters one for the sc and one for the turbo
The other one i rember was Dan Rucis, old rolla from perth, had a widebody feel's kit
Both really nice cars
JustinSpiderholden
Postby tsoob » Wed Jun 04, 2008 3:48 pm
you know what month hot fours? i remember the car just like to get the mag.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Crampy » Wed Jun 04, 2008 3:49 pm
Please, don't do it like this!!!
Crampy
Postby xsspeed » Wed Jun 04, 2008 3:59 pm
Thats some sweet braided hose going round the cambelt covers there :D
Postby Crampy » Wed Jun 04, 2008 5:30 pm
xsspeed wrote:Thats some sweet braided hose going round the cambelt covers there :D
Yep, pretty ugly isn't it. Not to mention the welding and the nice joins on the intercooler pipes.
I mean if you're going to go through the effort of twincharging, why use the 4AGZE intake and add to it, it's poo! The inlet manifold is $hit and it's so easy to make it way better.
That's the way the HKS twincharge kit worked, it just added to the 4AGZE.
I'd say if going twincharge, go for the same setup as the VW TSI motor and use a 4AGE inlet manifold for starters.
Crampy
Postby RomanV » Wed Jun 04, 2008 7:21 pm
Crampy wrote: But I suppose if you are willing to get it up and running, the torque delivery would be like a larger displacement engine.
fixed?
Postby Crampy » Wed Jun 04, 2008 7:31 pm
Na, I like it the way I said it better.
Crampy
Postby matt dunn » Thu Jun 05, 2008 12:41 am
barryogen wrote:Matt Dunn has played with twin charging, and had something like 30psi of boost at idle... I'd imagine it would make it almost undrivable.
Yeah, and it did.
We did back to back testing on a two day event and found that a s/c sucks too much power.
We removed the S/C and bridged it with a piece of exhaust tube bent into a u shape,
and the car was way faster and more driveable, easier on tyres, and more predictable.
Postby h8wrxs » Thu Jun 05, 2008 1:10 am
so basically i would be throwing money down the drain, because it couldnt be driven comfortably?
h8wrxs
Postby RedMist » Thu Jun 05, 2008 6:17 am
Twincharging is an 80's patch to large turbo lag. Turbos have come a long way in 25 odd years. I'd just spend a tonne of time playing with turbo maps until you find one that suits the power and delivery you want.
You wouldnt even be able to tell that my V6 is turbocharged if you didnt hear the blow off valves. Power delivery is that smooth and instant.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
