Cakky wrote:a silvertop will run better on a blacktop loom and ecu but will require custom wiring to make work I believe, I think AceSniper on here or someone may have done it, but can I ask why go to a silvertop?? whats wrong with replacing it with another blacktop would be a lot less hassle
sergei wrote:I don't believe there is need for custom wiring in this case, you could even use BT throttle body so not to muck around with MAP sensor line (well it is not that difficult anyway).
