w55 speedo drive
w55 speedo drive
Postby Jonno2002 » Wed Jun 11, 2008 9:21 pm
this is what ive got and aparently is "well queer" lol:
i need to convert it to mechanical drive as you can see the cable hanging there but this one doesnt unscrew and changeover like im told it should ?
any advice on wtf ive got here ? aparently the box came from a sx80 cresta but obviously it doesnt
Jonno2002
Postby postfach » Wed Jun 11, 2008 9:26 pm
Looks to me like you need to remove that 10mm(?) bolt and pull the whole sender assembly out and replace it with the screw type.
postfach
Postby Jonno2002 » Wed Jun 11, 2008 9:29 pm
yes thats true i know that BUT bens one is different his just screws off and on and uses the same actual drive part whereas this one doesnt
Jonno2002
Postby Lloyd » Wed Jun 11, 2008 9:31 pm
Take it out and see what is in there. Another whole drive unit may bolt in
Postby Jonno2002 » Wed Jun 11, 2008 9:35 pm
i did take it out, another unit will bolt in but the one i had from the auto box is way too small, i should have taken a photo but i didnt, ill get one tomorow since the box still has no oil in it
Jonno2002
Postby postfach » Wed Jun 11, 2008 9:38 pm
Can you please take it out and measure all the dimensions? I use the electronic sender in my box but mine is the screw in type, if its the same I'd be willing to swap with you.
postfach
Postby Jonno2002 » Wed Jun 11, 2008 9:46 pm
ok kool ill do it asap then thx
Jonno2002
Postby matt dunn » Wed Jun 11, 2008 9:56 pm
Yeah pull it out and take photo's and post them up.
would be keen to see what it's like as I am looking for an electrical sender for mine at some stage.
Matt
Postby thegreatestben » Wed Jun 11, 2008 9:59 pm
Matt if you are after another sensor I have another spare. The new cressida has a cable for the speedo so I don't need the one from the chaser.
Would be same as the last one i sent you, screw on type.
thegreatestben
Postby Jonno2002 » Fri Jun 13, 2008 8:33 pm
here you go, compared to the auto one:
the plug:
the sizes (close as i could with a tape measure):
Jonno2002
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
