lucasthefallen wrote:why will i need an after market ecu?
barryogen wrote:lucasthefallen wrote:why will i need an after market ecu?
running more boost the engine will be lean, and you will bust pistons.
I guess you could change the pulleys so that the SC14 was only providing 8psi, but it would probably make some other bits of the map wrong.
yes please pictures would be great, my email is projectsw20@hotmail.com, how difficult/complicated were the mounts to make?
soopachargen wrote:u keen to do a rwd one with an NA inlet manifold baz?:P
