Ok
From Fig 1
Ive ascertained that the loom on the left with 4 wires is for the fuel guage on the cars dash, so ignore that.
The loom on the right is for the pump unit its self.
4 wires each crimp into 2 pins.
The 2 pins on the right in white / Blue Black when un plugged and a multimeter is placed on the end of the blue black pin and earthed is 0v when you turn the key its 10-12v.
the white is 0v all the time.
BUT if you plug the plug in and multimeter the other end of the plug from the blue black region (where the green heat shrink is ) regardless of the keys position it stays around 0v as apposed to when it wasnt plugged in and it went up to 12vs.
By my understanding that its live 12v un plugged means no relays or fuses are stopping it powering the pump, the question is why it gets no voltage when its connected ( is this a sign the pumps had it? ) or is it a sign of somthing else that im not aware of the workings towards?
In fig2 you can see the "jumper" thats closing the fuel pump circuit, if i unplug that it goes off it should go in via the ecus 2 exposed wires but for reasons i wont bother explaining all you need to know is " it just doesnt, and this is how it is and has worked "..
