2tb twin side drafts
Postby Josh » Tue Jul 29, 2008 5:09 pm
Wanting to get a set of side drafts for my 2tb, I know that the inlet ports are 35mm in diameter, where would i find a set of 35 sideys and a mani to suit. Dont want to go 40's I was told they would be too big? Cheers
2tb kp60
Josh
Postby atmosports » Tue Jul 29, 2008 6:30 pm
Getting 35mm carbs would be the mission, especially new ones. Then once you get them getting a manifold to suit 35mm carbs would be fun unless you got some that are the usual dcoe/dhla side draft pattern.
Seriously 40mm carbs will be ok for the majority of road cars up to 1600cc & I'd say probably go to 45mm for up to 2L. It'll come down to the choke sizes/jetting really. We run 45 or 48mm carbs on some race engines that are 1300cc or less.
I'd say go for 40mm carbs & try & pick up some weber if you can though be careful buying s/hand as sometimes it can cost more by the time you reco thwm than new ones. A new pair of weber 40mm dcom is around the $1000 mark from memory, may still be able to get dcoe's without the emission control as well to give you idea.
As for a manifold there is usally factory/aftermarket manifolds for sale either here or on TM. Else HiTech Motorsport in Drury (09)294-6001 manufactures new cast aluminium side draft manifolds to suit for around $200
atmosports
Postby Josh » Tue Jul 29, 2008 8:39 pm
Oh ok sweet, but what about matching the port size, would I have to get the ports enlarged to 40mm, or would it be sweet with the standard 35mm ports
2tb kp60
Josh
Postby Josh » Tue Jul 29, 2008 8:40 pm
Also what sort of choke size would you reccomend?
2tb kp60
Josh
Postby atmosports » Wed Jul 30, 2008 5:25 pm
From memory the port size on those manifolds is around 32-35mm been a long time since I played with one, think it's just under 35mm which give you a little bit of material to play with to port match it to the head.
As for choke sizes, hard to know as I don't know the rest of the engine spec & how hard you'll drive it etc. But I could probably say you'd need 36mm chokes maybe or possible 38mm but until you tune it it's hard to say. I've even seen 32mm chokes used before on a 1600 with twin 40mm weber's it hard to say.
atmosports
Postby TRD Man » Thu Jul 31, 2008 9:52 am
I happen to have a set of 40 Webers on a 2TG manifold in the shed if you're looking.
TRD Man
Postby Dell'Orto » Thu Jul 31, 2008 1:10 pm
Different bolt spacing between 2T-B and 2T-G innit?
Postby atmosports » Thu Jul 31, 2008 5:07 pm
I'm sure I originally read it & it said 2tg not 2tb but who knows after the week I've had. As for 2tg & 2tb being different bolt patterns, sure I've been there before & sussed it out but have forgotten as it's not really an engine I play with.
atmosports
Postby Josh » Sat Aug 02, 2008 10:47 am
i could be keen on the set of webers TRD Man has, how much would you want, what sort of condition, choke size? Cheers
2tb kp60
Josh
Postby sleeektoy » Sun Aug 03, 2008 10:26 am
this site has a lot of performance parts for 2T/3T
http://www.brdracing.com/toyota_2tc_3tc_engines.htm
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby Prymal » Wed Aug 06, 2008 1:30 am
redline manifolds in australia sell a 2tB manifold to suit side draft 40 and 45 carbs
I ran a sidedraft 45 , in single coinfig on my ex race motor 2tb , with their products and was a very happy fellow :)
stuff aint cheap , but the workmanship is very very good
Prymal
Postby AE86fan » Wed Aug 06, 2008 6:31 pm
I had 45mm Webers on my 2TG, with 34mm chokes from memory and it went good. I found with the smaller choke size it gave it good response at lower revs which suited rallying, especially as the 2TG wasnt really a high reving engine compared to the 4age.
From reading your post Im not sure if you realise most inlet manifolds taper down from the carb to the inlet port....
1984 NZ AE86
AE86fan
