Brake Booster? or Master cylinder?
Postby metric » Sun Aug 03, 2008 5:34 pm
Have a problem with the brakes on my car, the pedal works fine etc goes in comes out etc
but the brakes are not releasing properly so they stay on and get hotter and hotter untill brake fade is a problem.
A good example is:
Changed to an lsd yesterday, so i gave the rear brakes a going over while they were off. Went for about a twenty minute drive and came home put it in the shed and went to push it forward a bit more and its really hard to push.
Come back an hour later and gave it the same push and it rolled into the tires i had at the front of the shed.
Had this for a while now but was on three brakes and since yesterday its all four?
Anyone got any ideas? thinkin Brake Booster?
metric
Postby l1ttle_d3vil » Sun Aug 03, 2008 7:21 pm
pistons aren't sticking in the calipers are they?
Postby metric » Sun Aug 03, 2008 8:12 pm
would having one stuck affect the rest?
metric
Postby MAGN1T » Sun Aug 03, 2008 8:33 pm
It's usually a flexible hose that collapses partially blocking it.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby metric » Mon Aug 04, 2008 9:20 am
now that i think about it i did replace that hose about 6 months ago, and it does run above the exhaust
will try that and see
metric
