Clutch switch for launch control/flatshift
Postby ChaosAD » Mon Aug 04, 2008 11:27 pm
Im wiring up an aftermarket ecu which has an option for launch control/flatshift and need to put some sort of switch on the clutch.
What do most people use? A magnet and reed switch? or are there better switches available?
It needs to be closed when the clutch is in
ChaosAD
Postby method » Mon Aug 04, 2008 11:34 pm
Used magnet and reed switch on mine. Worked well.
PICS UPDATED DAILY
method
Postby ChaosAD » Mon Aug 04, 2008 11:35 pm
ChaosAD
Postby mister2 » Tue Aug 05, 2008 9:49 pm
Not sure what chassis you're using, but I was able to screw in a brake pedal switch pretty easily into the aw11; just had to remove a bolt.
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby matt dunn » Tue Aug 05, 2008 11:41 pm
mister2 wrote:Not sure what chassis you're using, but I was able to screw in a brake pedal switch pretty easily into the aw11; just had to remove a bolt.
Mine was very similar on my Ke70, the bracket was there, just needed another brake type switch.
