SW20 driveaxles, differences and shortening.
Postby touge rolla » Tue Aug 12, 2008 4:37 pm
Ok have my MR2 (1990 turbo btw) almost back together after changing the gearbox to one from a gen3 to find the driveaxles are about 5mm from going all the way in and won't budge anymore. So I'm guessing the gen3's have a driveaxle with a slightly shorter spline, yes?
If so can I simply grind a couple of millimeters off the ends of my ones so they fit? (new driveaxles out of my budget atm)
Thanks.
touge rolla
Postby Akane » Tue Aug 12, 2008 4:44 pm
Yeap they're different, dunno about grinding all the amerikans on mr2oc just get the proper driveshafts, so I take it as a no.
Postby pureadrenalin » Wed Aug 13, 2008 9:03 am
Yep, slightly different. I just got the proper axles when I got the newer gearbox (good luck finding hen’s teeth).
I’m guessing that you have the stock LSD in there? I have a suspicion (can’t confirm it yet) that if you have an aftermarket LSD (cusco, Kazz, etc) they will accept either gen’s axles. I have a cusco in mine.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together
pureadrenalin
Postby touge rolla » Wed Aug 13, 2008 3:49 pm
hmmmm interesting about aftermarket LSD, really raises the question to Toyota, Why? nm.
Yes they're not that easy to find compared to the earlier model stuff (changing the suspension resulted in less getting written off I guess lol)
touge rolla
Postby fivebob » Wed Aug 13, 2008 4:19 pm
touge rolla wrote:hmmmm interesting about aftermarket LSD, really raises the question to Toyota, Why?
Because the LSD diff has a cross bar for the spider gears that the longer axles hit.
Postby touge rolla » Wed Aug 13, 2008 4:24 pm
ok, makes sense then. And confirms that my new gearbox is LSD :D
I think I'll try grinding them first (what have I got to lose?)
touge rolla
Postby kim0663 » Wed Aug 13, 2008 4:38 pm
touge rolla wrote:ok, makes sense then. And confirms that my new gearbox is LSD :D
as far as i have found out, all JDM gen2 + models that are 3sgte powered all came with a viscous lsd. so if its a gen3 box, DEFINATLY lsd :)
Mr2 GT-S
330ci M
kim0663
