AE111 & AE101 superstrut brakes
Postby Maxwedge » Thu Aug 14, 2008 8:20 am
I need to know whether the front brake disc from a Superstrut AE101 has a 54mm centre hole or 55mm, I have a disc from a Superstrut AE111 which has a 55mm hole and need to know whether the AE101 is the same, thanks
Maxwedge
Postby Crampy » Thu Aug 14, 2008 10:17 am
AE101 and AE111 are the same from what I see.
Crampy
Postby neo » Thu Aug 14, 2008 8:49 pm
ae101 center is 55mm, ae111 center is 54mm
ae101 is the odd one out when it comes to hubs / brakes in the corolla family.
neo
Postby Maxwedge » Fri Aug 15, 2008 9:08 am
Are you sure about that, I have some superstrut brakes from a BZG and they have the 55mm centres. I am trying to establish whether the AE101 has the 54mm hole so I can fit to a AE82 use the twin pot calipers and machine the diameter of the disc.
Maxwedge
Postby Glycerine » Sat Aug 16, 2008 12:46 pm
Glycerine
Postby Allister S » Mon Aug 18, 2008 2:17 pm
Strange - I'm just doing this swap and ordered new discs from Toyota for a AE101-bcmzf, 5027333 and got 54mm bore SS discs.
Machined the OD down and are now making up a thin spacer (only 1.6-2mm thick) to go UNDER the disc (as the disc doesn't sit central to the pad carrier - closer on the inside). This is something I found but I've not seen it mentioned in any conversion notes? Anyone else found this?
NZ AE82 GL Liftback Tarmac Rally spec
NZ AE82 GT Liftback x 2
R32 Skyline GTS-t Type M Coupe
'07 Subaru Legacy GTB
'03 Runx 2ZZ-GE 6spd
Allister S
