engine oil light on
engine oil light on
Postby kenze » Thu Aug 21, 2008 10:31 pm
got a 92 cynos with 5e,starts fine,drives fine,after around 5 mins driving,engine oil light on. turn it off about 15 mins,start again, its off and after 5 mins drive,it would come up again.
anyone can help!!!
before all these happen,just changed cambelt and waterpump.
and i changed the new oil and c if there is any different,but no luck it come up the same result.
is the oil pressure switch/sensor a common problem for 5e?or could be somthing else?
kenze
Postby Mr Revhead » Thu Aug 21, 2008 11:26 pm
a faulty oil pressure switch is not uncommon on toyotas
Postby Leon » Fri Aug 22, 2008 8:40 am
as I replied to this exact same post on NZHonda's ... don't drive it until you're sure, as I've had a car with the same symptom and it was a blocked oil filter, so was pretty major problem.
Postby kenze » Sun Aug 24, 2008 11:41 am
just changed a oil pressure switch,its going good and no light any more.not sure if i completely fixed the problem.may be still better to check the oil pressure.any suggestion?
kenze
