rollaholic wrote:you'll need to find a way to convince the fuel pump to give you more diesel before you are going to see any benefit from more air
fivebob wrote:rollaholic wrote:you'll need to find a way to convince the fuel pump to give you more diesel before you are going to see any benefit from more air
Precisely. Diesels are fuel limited not air limited. So, unless you can change the characteristics of the pump to give you more fuel down low, then it's a waste of time fitting a device that gives you more air at that point.
IMO turbos are a better option for diesels because the drive losses in a supercharger make it too inefficient, given the low rpm that a diesel operates you'd have to gear the supercharger quite high and that makes the losses worse. Superchargers are usually only found of two-stroke diesels, don't know why that is.
toyrota mota wrote:rollaholic wrote:you'll need to find a way to convince the fuel pump to give you more diesel before you are going to see any benefit from more air
Ahhhh turn the screw on the fuel pump to give me more diesel??????
fivebob wrote:[Precisely. Diesels are fuel limited not air limited. So, unless you can change the characteristics of the pump to give you more fuel down low, .
Phothog wrote:toyrota mota wrote:rollaholic wrote:you'll need to find a way to convince the fuel pump to give you more diesel before you are going to see any benefit from more air
Ah..... which screw though.
there is 3 adjustment screws on the pajero pumps..
1 for non boost fuel
1 for mid boost fuel
1 for overall fuel ...
99.9% of jap turbocharged vehicles have a boost compensator on them,
it sensors boost & pushes something in the pump to give more fuel.
also one problem on the 4D56 is the pressure valve on the inlet manifold, they open at about 15psi (from memory)
Best thing for the Old pajeros..... apart from selling it & getting a Toyota.
Air to water i/c (if its not intercooled) and a 2 1/2" exhaust
and give one of those fuel screws a turn.
Chris.
toyrota mota wrote:Hahaha just having an intercooler would be an upgrade.
fivebob wrote:Superchargers are usually only found of two-stroke diesels, don't know why that is.
