by MAGN1T » Mon Sep 01, 2008 1:41 pm
The only time I've seen that, the head was cracked. It started off as just a blown headgasket, lost water, overheated, filled up blah blah, finally changed the headgasket, got worse, found the crack when the cam was removed. That was in a Nissan E15.
Steve
Computers make you go mad.
