idle problems
idle problems
Postby TRD_ZERO » Thu Sep 11, 2008 10:48 am
Ive got a friend that just purchased a ae101 fxgt and when the car is cold the idle is all over the place from 1700 to 500, it just goes up and down like crazy until it gets warm then it stabelises at about 900. What is causeing it to idle like that only when cold?
Yes ive done a search and did find some interesting things but the problems my friend is experienceing isnt quite the same His only idles like crap when cold.
TRD_ZERO
Postby ~SlideWays~ » Thu Sep 11, 2008 12:56 pm
Possibly a vacuum leak, check for any loose hoses.
~SlideWays~
Postby AE82 FXGT » Thu Sep 11, 2008 1:25 pm
Or splits in any intake/vacuum lines/pipes
AE82 FXGT
Postby thegreatestben » Thu Sep 11, 2008 1:38 pm
Check your ISCV
thegreatestben
Postby TRD_ZERO » Thu Sep 11, 2008 4:29 pm
~SlideWays~ wrote:Possibly a vacuum leak, check for any loose hoses.
I thought it could be that but they why would it only do it on cold and be perfectly fine when warm?
tgb.mr2 wrote:Check your ISCV
what is that, where is it located and what do i check for?
TRD_ZERO
Postby Crimson Tears » Thu Sep 11, 2008 7:08 pm
+1 on checking the idle speed control valve.
They get blocked up with carbon and then won't function correctly.
Should be close to the throttle body, it will have a plug, and a couple of coolant hoses (normally). Remove it, clean out the air passages with some carb clean, dry it out then refit it.
Crimson Tears
