Boost problem
Boost problem
Postby samlloyd » Sun Sep 14, 2008 11:56 am
My rb30det isnt boosting as much as it was a few days ago. Under WOT it wont go over 1Bar, when it would normally see 1.2
All intercooler hoses seem ok, and it idles sweet (once warm)
Any ideas?
samlloyd
Postby 79rolla » Sun Sep 14, 2008 12:03 pm
wast gate actuator?? turbo dieing?? a hoes poped off somewhere??
past: AE82 FXGT
79rolla
Postby MR2SIK » Sun Sep 14, 2008 12:31 pm
is the vacuum showing the same as usual on the gauge? if not it could just be the hose for the gauge springing a leak, happened to me once. spent ages trying to find a non exsistant problem :oops:
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby samlloyd » Sun Sep 14, 2008 5:42 pm
Vacuum doesnt appear to be out of the ordinary.
I dont think a hose has popped off as this would cause an irratic idle.
Turbo dieing could be a possibility, but the shaft still feels ok.
Wastegate actuator feels fine, and can only open once there is enough pressure there.
I feel there is a leak only when under boost. It sounds kind of like an external, but with air more then exhaust. I will check all the exhaust flanges aswell. But for it only to be doing it when under high boost.
(you can only hear it leak at about .9 Bar)
samlloyd
Postby Twolitre » Sun Sep 14, 2008 7:44 pm
Common problem with Rb's apparently is broken exhaust manifold studs causing an exhaust leak. Look for traces of carbon around your exhuast manifold and exhaust housing flanges.
Twolitre
Postby samlloyd » Mon Sep 15, 2008 12:38 am
You would think that the exhaust leak would be all the time, not just when its under full boost. But i wll check, thanks
samlloyd
Postby samlloyd » Mon Sep 15, 2008 10:25 pm
Looks like ive found it, the screw in the top of the blitz BOV has gone walkabouts. Now, where to find a replacement
samlloyd
Users browsing this forum: Bing [Bot] and 15 guests
