TRD_ZERO wrote:Didnt gasman run factory valve springs on 20psi? And i think maybe even flygt4
rollaholic wrote:change 'bit of fun' setting to 17-18 psi
profit
escortman wrote:u can run stock 1s but y not do it all now
bluemaumau wrote:why dont you pm them?
i was under the impression you needed to upgarde at around 2 bar
TRD_ZERO wrote:
Pm them? The head specialist sad anything over about 15psi needs uprated springs. He is a head specialist he does this for a living is he wrong? But then how is gasman and flygt4 and matt dunn getting away with it?
TRD_ZERO wrote:escortman wrote:u can run stock 1s but y not do it all now
Because of the cost of it, new ones are around $300. Like i dont have other expensesbluemaumau wrote:why dont you pm them?
Pm them? The head specialist sad anything over about 15psi needs uprated springs. He is a head specialist he does this for a living is he wrong? But then how is gasman and flygt4 getting away with it?
I run factory valve springs and 20psi all the time.
haven't had a problem with them, running with standard cams.
but the engine builder also had my aftermarket cams when we first built the engine and said that they would be fine, but were very close to coil bind with the aftermarket cams.
