missing un even idle etc
Postby tech128 » Tue Sep 16, 2008 8:34 pm
4agze map coil pacs etc has a missfire
when the car is cold it has a flatspot etc
have changed plugs leads fuel filter big survice super charger oil etc
tech128
Postby Bling » Tue Sep 16, 2008 11:28 pm
where in the revs is the misfire? or is it inconsistent? Only when engine is cold?
Postby gepsk8 » Wed Sep 17, 2008 9:52 pm
trouble codes?
O272754663
gepsk8
Postby samlloyd » Wed Sep 17, 2008 10:38 pm
same, would like to know outcome. Different motor though, i made a thread and addressed problem but no result
samlloyd
missfire
Postby tech128 » Wed Sep 17, 2008 10:42 pm
hooked it up on te1 an e1 got two flashes and nothing lse so imguessing
code 11 or 2 any 1 have ideas on a rare ocasion the engine light comes on
tech128
Postby Crucible » Wed Sep 17, 2008 11:03 pm
if there was a short pause after the first lamp pulse, itll be 11.
i cant tell you what that code is off top of my head, itll be on here somewhere, but yeah you need to get that check lamp out before going any further, somethings not right there!
my ae101 ran like crap in limp home mode!, couldnt rev it and it wouldnt hold idle very well.
Crucible
Real Life Mechanic
Postby gepsk8 » Wed Sep 17, 2008 11:30 pm
that saying its ecu, if its 11.
O272754663
gepsk8
missing
Postby tech128 » Thu Sep 18, 2008 7:56 am
its got an eratic idle idles at 1500 rpm when cold and has a flatspot bwfore the charger kicks in
i cant get the codes to work now either
il have a look at the ecu
tech128
