pressure switch
pressure switch
Postby groupagt4 » Wed Sep 17, 2008 7:50 pm
i need a pressure switch that will give power to a soleniod that opens a extra fuel feed to my carb when boost reaches about 5 psi. anyone have a idea where i can get one, adjustable would be best
groupagt4
Postby Akane » Wed Sep 17, 2008 9:40 pm
What you need is a Hobbs switch, google for it for more info.
Postby Crampy » Thu Sep 18, 2008 10:59 am
You could use a MAP sensor from a Turbo car and make up a circuit to suit. Put the output of the MAP sensor into the "+" input of a comparator circuit. Easily adjusted with a variable resister to change the reference voltage to the "-" input to the comparator.
Eg, when the MAP voltage (eg boost level) gets above the preset amount (eg 5 psi set with the reference voltage), the output of the comparator swithes on.
Then use the output of the comparator to drive a transistor (or relay) to engage the solenoid.
Easy.
Crampy
Postby strx7 » Thu Sep 18, 2008 3:51 pm
pretty sure your nearest electrical components supplier ie: J A RUSSELL sell pressure switches which do the job
Postby matt dunn » Thu Sep 18, 2008 11:52 pm
I can supply a hobbs pressure sw,
but they are close to $100 from memory,
OR,
Use an oil pressure switch ($19) and a change over relay. ($10)
