4agze into ke70 dx wagon
Postby nandor markos » Sun Sep 21, 2008 7:53 pm
I currently have a ke70 dx wagon that i was prepping for a 12a conversion but due to my engine not arriving i have decided to strip my ae92 gtz and put everything into the dx.
i'm just wondering if anyone can give me some advice on how to go about it, do i need to change mounts, what parts are adaptable eg clutch cylinder brake cylinder do i need to change the clutch and flywheel for rwd will a t50 bolt straight up etc, and i would like to use as many ae92 parts as possible.
I am also trying to fit ae86 adjustable suspension but the lower arms are to short, i was told later model dx arms would work but they are the same as mine. Also i will be fitting ae86 brakes front and rear do i need to change much for this?
Any help would be greatly appreciated as i have never attempted a conversion like this before
nandor markos
Postby escortman » Sun Sep 21, 2008 8:24 pm
search for the bits about 4age fitting
4x4 toyota blizzard offroader
escortman
Postby rollaholic » Mon Sep 22, 2008 8:25 am
if you look at ricks project thread on his ae85 should give you some good ideas, will be quite similar to ke70 i would imagine in terms of fitting the engine. apparently the SC touches one of the engine mounts in RWD setup so need to work around that (he used a grinder iirc, haha)
