Dell'Orto wrote:It'll still be illegal if its noisy.
l1ttle_d3vil wrote:and externals can't be any noisier than most BOV's.
xsspeed wrote:They dont call them screamers for nothing.
TBH it would be a waste, if you cut cost and use small diameter pipe you are going to get too much pressure build up. If you use a big pipe you might as well put it into the larger exhaust pipe anyway, plus that way it will be muffled and legal
xsspeed wrote:I've never personally seen a system like that
touge rolla wrote:xsspeed wrote:I've never personally seen a system like that
Really, they're becoming increasingly common down here, see them everywhere. If it's not too loud it will be fine, no advantages though other than noise (which is also a disadvantage).
Save weight just plumb it back in.
HRT wrote:And isn't loud and has a form of muffler in the system
groupagt4 wrote:just run it the way you want man. i got mine plumbed in to save weight and keep the rear of the car clean. have seen it run to the rear in a pretty serious sti track car and it wasnt loud at all so noise shouldnt be an issue
