2tb, 2tg sidedraft manifolds interchangeable?
Postby Josh » Fri Sep 26, 2008 6:12 pm
As title states, would a sidedraft manifold for a 2tg bolt up to a 2tb. Also what sort of size is a 40mm sidedraft set up, thats width with the manifold, carbs and filters, Cheers
2tb kp60
Josh
Postby Prymal » Fri Sep 26, 2008 7:45 pm
nope - they dont
Sorry!
redline in australia ( manifold maker - not the HKS supplier miob in auckland ) have a setup to suit both twin and single 45mm DCOE webers..
Ive used one to great effect on my first ta22 / 2TB
the other option is a convincing yourself to go straigth to a 2tg , with sidedrafts already on it :)
Prymal
Postby sleeektoy » Fri Sep 26, 2008 10:58 pm
I believe autoquip marketing in auckland may be able to source the same manifold that you need
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby Josh » Mon Sep 29, 2008 9:56 pm
sweet, can anyone give me an idea on the size of a sidedraft set up, doesnt have to be exact, just want to see if it would fit in my car, cos the carbs on the 2t are on the opposite side of what the k series were
2tb kp60
Josh
Postby Josh » Fri Oct 03, 2008 4:57 pm
What about the exhaust manifolds, are they interchangeable, still wantin a rough idea of sidedraft set up size, cheers
2tb kp60
Josh
Postby AE25 » Mon Oct 13, 2008 7:24 am
all T engines have same exhaust manifold flange size so can interchange exhaust manif.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
