feul rail outlet
feul rail outlet
Postby NOLAW » Wed Oct 01, 2008 1:17 pm
ok im running all steel braided teflon lines on my 4agte and i have fittings for everything but the outlet of the feul rail, what do i use here? im stumped, is there like an adapter i can use that pushes in and a fitting screws on to? any help is much appreciated
NOLAW
Postby l1ttle_d3vil » Wed Oct 01, 2008 1:22 pm
i got a heap of fittings for 4age fuel rails here. bring your rail round some time and try some of them if you want
edit - oh you're using an aftermarket fuel reg though aren't you? otherwise its just the standard regulator which goes in there, i got a few here.
Postby NOLAW » Wed Oct 01, 2008 2:08 pm
hey matt, yeah im running aftermarket reg etc, i do remember seeing something last year on trademe, i think it was a push in thing with a screw on thread that allows you to screw on a fitting then feul line, i just have no idea where to get one now as i havnt seen them for ages, and i think thats what i need, does anyone know where to get these?
NOLAW
Postby Bazda » Wed Oct 01, 2008 2:09 pm
Think he needs a adapter to AN fitting.
You can either get a little plate made up then weld a AN fitting onto it (would be -6 in size) or you can buy the adapter plate with it on.
Or you buy this adapter plate, only problem is you have to use rubber push on hose with a hose clip. Everything I supplied you was screw on (leak free :D).
http://www.trademe.co.nz/Trade-Me-Motor ... 802784.htm
Postby NOLAW » Wed Oct 01, 2008 2:43 pm
hey baz, yeah definatly not wanting a push on type, where can i buy a ready made plate with AN fitting on it?
NOLAW
Postby Bazda » Wed Oct 01, 2008 3:45 pm
NOLAW wrote:hey baz, yeah definatly not wanting a push on type, where can i buy a ready made plate with AN fitting on it?
Dont think you can buy one.
What I did with mine and IH8TEC's is put a thred into that outlet hole.
I used a 1/4 to -6 fitting. Got a pipe flare tap the same thread, drilled out the hole to the correct size (around 11mm) and ran the tap through.
You can see it in this pic.
Postby NOLAW » Wed Oct 01, 2008 3:52 pm
sweeet that sounds like the way to go, cheers mate 8)
NOLAW
