1ggte running like poo
Postby escortman » Fri Oct 03, 2008 2:22 pm
mates got 1g in his hilux and just after getting it going from been sitting 6months been painted has slowly began to run like crap, it started off just been a slight miss on boost, but now stalls at 1 psi, any ideas? already done new leads and dizzy cap, tried differnet coil and afm nothing changed
4x4 toyota blizzard offroader
escortman
Re: 1ggte running like poo
Postby ~SlideWays~ » Fri Oct 03, 2008 2:50 pm
escortman wrote:mates got 1g in his hilux and just after getting it going from been sitting 6months been painted has slowly began to run like crap, it started off just been a slight miss on boost, but now stalls at 1 psi, any ideas? already done new leads and dizzy cap, tried differnet coil and afm nothing changed
Sparkplugs?
~SlideWays~
Postby escortman » Fri Oct 03, 2008 9:08 pm
cleaned and tried again then thought maybe turn fuel reg down and noticed when u reved it the fuel press dropped to almost 0 so gona pull fuel tank 2moro and check how the pump is sitting as had to make custom (rangi) bracket to hold walbro 1
escortman
Postby ChaosAD » Sat Oct 04, 2008 12:17 am
Disconnect the battery, hold foot on brake for a while, reconnect battery after several hours and see if that makes any difference
ChaosAD
Postby barryogen » Sat Oct 04, 2008 1:47 pm
escortman wrote:noticed when u reved it the fuel press dropped to almost 0
check the fuel filters... it may be blocked enough that as soon as it is under any load it can't supply enough gas.
barryogen
2ZZ Guru in training
Postby escortman » Sat Oct 04, 2008 7:48 pm
ChaosAD wrote:Disconnect the battery, hold foot on brake for a while, reconnect battery after several hours and see if that makes any difference
whats that going 2 do
escortman
Postby escortman » Sat Oct 04, 2008 7:49 pm
yeh was the filter on the pump was blocked
escortman
Postby barryogen » Sat Oct 04, 2008 9:21 pm
at a guess, reset the ECU(clear error codes) if it does it on that model.
escortman wrote:
barryogen wrote:check the fuel filters... it may be blocked enough that as soon as it is under any load it can't supply enough gas.
woohoo, what do I win? :)
barryogen
Postby escortman » Sun Oct 05, 2008 11:42 am
o i thought resetting ecu was just taking power off for 1min or something
hahah u won ..................... a bag of carrots :lol: il try get some picks up of it
escortman
