caldina gtt lean mode on ecu??
Postby Nick2nv » Sat Oct 04, 2008 12:34 pm
question: do the caldina gtt's have a lean mode that the ecu switches to? just found out that my car has been run on 91 octane arrrrrrrrrrrrrrr :( i know subaru's have this do caldinas? and does it have to be reset or does it come right ?
Nick2nv
Postby barryogen » Sat Oct 04, 2008 1:58 pm
Not sure what you mean by lean mode, but most new ish ecus will adjust(retard) timing if you put crap gas in.
I would assume that if you put 98 in it for a while it'll re-adjust(advance) timing again.
There may be a trick like pulling the efi/ecu fuse and leaving it for 10 mins or so to speed this up.
barryogen
2ZZ Guru in training
