Wheel Gurus
Wheel Gurus
Postby B1NZ » Sun Oct 05, 2008 9:30 am
If someone advertises a wheel like this:
6JJ x 14 +38 PCD, will this fit my 1990 AE92 FXGT correctly?
The +38 is the offset I think, Is the 14 4X100? what is the 6JJ?
I have no idea what my FXGT is apart from 4X100
Thanks in advance
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby fangsport » Sun Oct 05, 2008 9:34 am
14 is diameter
6jj is 6 inch wide
+38 is offset
you would need to find out what the PCD is for your fitment
fangsport
Postby THA SHZ » Sun Oct 05, 2008 11:06 am
yes 38 offset in a 6 inch wide in a 14 inch wheel will fit your ae92 .
THA SHZ
Postby fangsport » Sun Oct 05, 2008 12:07 pm
THA SHZ wrote:yes 38 offset in a 6 inch wide in a 14 inch wheel will fit your ae92 .
............... only if the PCD is correct
fangsport
Postby B1NZ » Sun Oct 05, 2008 3:39 pm
thatks for the help, yeah I googled PCD and found out that PCd means pitch circle diameter ie. the 4X100 etc thing, so he is incorrectly saying these numbers are the PCD, have advised and am waiting for a reply, thank you all
Subaru GF8 Wagon
B1NZ
Postby Lloyd » Sun Oct 05, 2008 3:48 pm
PCD probably wont be on the wheel, he will have to measure between the centres and see what it is. Should be pretty obvious to him if its 4x100 or 4x114
Postby rollaholic » Sun Oct 05, 2008 5:12 pm
JJ describes the shape of the beading the tyre sits on :P
