Bearing verification
Postby TRD_ZERO » Mon Oct 06, 2008 5:07 pm
Ok so im about to order my bearings. the engine reconditioner said that they are standard size (bigend and mains). Im just wanting to make sure i use the right part number when ordering parts.
http://www.aclperformance.com.au/Toyota4A-GE4A-GEL.htm
thats the site im getting the part numbers off. The 16v and 20v bearing are all the same numbers. So for ordering the bigends do i use 4B1780H or 4B1780HX? And when giving them that number do i also tell them standard size? And same thing with the mains do i use part number 5M1695H or 5M1695HX? and also just say standard size? The thrust set is easy as there is only one code 2T1695. Its just the mains and bigends that im not too sure what code to use.
TRD_ZERO
Postby Dell'Orto » Mon Oct 06, 2008 5:30 pm
X just means it has more clearance, if its a standardish rebuild then go for the plain race series. Just ask for 4B1780HSTD and 5M1695HSTD
Postby TRD_ZERO » Mon Oct 06, 2008 5:41 pm
Dell'Orto wrote:X just means it has more clearance, if its a standardish rebuild then go for the plain race series. Just ask for 4B1780HSTD and 5M1695HSTD
its going forced induction
TRD_ZERO
Postby Dell'Orto » Mon Oct 06, 2008 6:09 pm
Its not a race engine though is it? ie not going to revving its tits off most of its life.
Postby TRD_ZERO » Mon Oct 06, 2008 9:17 pm
nope ill get what you suggested thanks
TRD_ZERO
