BZG|Bling wrote:Has be covered many times if you do a search. I understand what HRT is saying, but i've done it a few times. So if you need more info than above do a search. Its not too hard to bleed em if you read up on it first
KinLoud wrote:- Don't tighten the bleed nipples too much when you are finished
KinLoud wrote:I use the repco dot5.1 brake fluid.
1 500ml bottle is usually enough but I always get 2 bottles so I don't run out!
Stuff they don't tell you...
- Don't shake the bottle as this will add airbubbles to your brake system
- Don't buy the stupid "one man bleed kits". I haven't found one that is actually useful yet. Just get someone to help you.
Go Nuts
Ken
Auck
021 408 863
postfach wrote:Nah, you should always use the best fluid you can afford, I use motul rbf600 in my daily driver, brakes are important, never skimp.
touge rolla wrote:A lot of the good DOT4 is rated up to 5.1
I've been using the Castrol DOT4/5.1 stuff for a couple of years now and it's been sweet. Even after taking the Zed on the track the brakes are still firm.
postfach wrote:Just for the sake of adding more info to the thread, not all DOT5.1 fluids are created equal, some will have much higher boiling points than others even though they have the same rating, it's something worth looking at if you plan on doing any spirited driving or taking your car to the track.
cat007 wrote:touge rolla wrote:A lot of the good DOT4 is rated up to 5.1
How long between fluid change?
