fan only works on high
Postby Cakky » Mon Oct 27, 2008 2:53 pm
ae92 corolla gt
fan will only work on auto and high, no low or medium? what would make this happen
1989 Corolla GT sedan blacktop 20v
Cakky
Postby Lloyd » Mon Oct 27, 2008 2:59 pm
Dead resistor pack. Will be in the heater box somewhere with a few (4ish) wires going into. Cant remember off the top of my head exactly where it is on those
Postby soven » Mon Oct 27, 2008 3:09 pm
Yea find the resistor pack, it is probably the fuse that is blown on it. It is a thermal fuse and you can just buy a similar rated one and either solder or just twist it on.
I changed mine and bought the resistors from RS components. $1 ish or something.
soven
Postby fangsport » Mon Oct 27, 2008 5:15 pm
also check the relay.
hilux and ae101 seem to cause issues
fangsport
Postby gepsk8 » Tue Oct 28, 2008 10:49 am
pm if u cant fix, can do it as perky.
O272754663
gepsk8
Postby xsspeed » Tue Oct 28, 2008 11:04 am
If AE82 is anything to go by it (resistor pack) is behind the fan speed controls.
Should have three or so coils, you will see that two of them will be broken
Postby MrOizo » Wed Oct 29, 2008 6:00 am
Normally these are in the flow of air from the blower as its what cools them.
In the supras, they are just after the blower and are easy as to get to. used one from a starlet if i recall correctly.
MrOizo
Toyspeed Legend
