86 diff and axel Qs
86 diff and axel Qs
Postby d1 mule » Wed Oct 29, 2008 8:38 pm
ok anyone know what sort of power standard 86 (pre face) axels can take??
what sort of power can a TRD 2 way take??
anyone used a hydraulic handbrake with a 86 diff??
ideally i want about 150RWKW when im done with the 70
im throwing ideas around doing TRD 2 way with hydraulic handbrake if that will sort the shit standard handbrake.
will most likely be running a wilwood boosterless system if that affects anythin?
thanks
d1 mule
Postby rollaholic » Thu Oct 30, 2008 7:09 am
hey man,
from my reading its not so much the LSD itself that will cause you problems - the common breakage area on T series is C & P and axles shearing. obviously a TRD LSD is not going to address those areas, and they'll both take a fair bit of abuse on a drifter.
Postby d1 mule » Thu Oct 30, 2008 10:52 am
oh right, but would a LSD be better that a locker in terms of longevity of those parts as there isnt the extreme stresses when jusd turning, only when sliding?
d1 mule
Postby Stealer Of Souls » Thu Oct 30, 2008 2:20 pm
My TRD 2 way is pretty savage...
Not locker savage, but still locks up quite quickly (if that's even an accurate way to describe it).
I've mulched three crown wheel/pinion sets so far.... All were 2nd hand, and one of dubious condition to begin with. Normally you end up wearing all the surface hardening off, makes a heck of a noise, but still functional.
(All that with standard 4AGE)
I'm reasonably certain I got told that the facelift axles aren't much good over 150kW...
'86 AE85.5 Levin
Stealer Of Souls
Postby d1 mule » Thu Oct 30, 2008 2:23 pm
ok the car will be 95% track only so wont have the day to day ware etc. im thinking it "should" be ok itll prob be just 4age 75 RWKW for a while yet any who
d1 mule
Postby AE25 » Thu Oct 30, 2008 11:58 pm
interesting to see how some people can destroy T diffs with an n/a 4age and then others track race them with lsd and slicks and never have an issue!? (eric's te71 3tgte 1800 turbo to be precise). or glenn i think ran the std T series irs with lsd behind a 7agte carina and never broke it.
i've broken a couple early type axles myself running a locker.. which after some use on the street became really chattery round corners as the axle spline wore out.. until a little 1st gear skid in the wet broke one with a std 2tgeu. so engine power wasn't the cause of failure!!
the other axle broke tramping behind a 3tgte. if i had open diff or lsd i don't think i'd have an issue. moral of story dont run a locker on the street! i never ran any wider than 195.50.15 either so i guess that was the fuse in the driveline.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby d1 mule » Fri Oct 31, 2008 10:26 am
wicked cheers.
yeah im thinkin a LSD should be ok. and like you cau ppl like nick tboon are running 200rwkw and they are fine, i should be right lol
d1 mule
Postby Logan » Fri Oct 31, 2008 11:03 am
or you could come out to a race/sprint @ ruapuna and talk to a few people who have been racing with full slicks and t series rear ends for AGES with out dramas....
SR Sold. Onto Other Things
Logan
Postby d1 mule » Fri Oct 31, 2008 12:05 pm
haha awesome, the news gets betta and betta
d1 mule
Postby NZ_AE86 » Sun Nov 02, 2008 8:28 pm
Slicks and alot of hard racing with no trouble here, early axles but they are custom made. The axles have dealt with 5 years of pain and suffering, as has the Crownwheel and Pinion.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
