Oil pressure and temp
Postby cat007 » Wed Nov 05, 2008 12:16 pm
Hey all,
I've been reading this:
http://supramania.com/aehaas/
Trying to get my head around it - might take a few times before it all sinks in. Thought it might be nice for others to have a read of it!
Question is this: in the article he suggests that engine oil temp can get as high as 150C. I've seen 100C on my gauge and thought that was high.....I guess not?
Postby gepsk8 » Wed Nov 05, 2008 5:34 pm
150 f?
O272754663
gepsk8
Postby cat007 » Wed Nov 05, 2008 5:52 pm
No. 150f isn't even 100c
He's talking over 300f.....
Postby Bazda » Wed Nov 05, 2008 6:37 pm
mine got to 150deg C. I added in another oil cooler. cut down to 120deg.
Think I need to make some ducts to my main oil cooler.
Postby matt dunn » Thu Nov 06, 2008 12:46 am
150 c is still alright for oil temps,
we had diff oil temps of close to 200 c in the focus before we added a cooler.
oil takes a lot longer to get to temp than water,
and usually runs hotter then water temps too.
usually 20 to 30 above water temp is normal
Postby kim0663 » Thu Nov 06, 2008 4:50 am
so at what temp should you be WORRIED? lol...
my oil pressure guage read 0psi once @ idle... pressure would rise with some throttle but was kinda scary. how hot would that be...? oil is mobil1 5w50
Mr2 GT-S
330ci M
kim0663
Postby MAGN1T » Thu Nov 06, 2008 9:10 am
It comes down to WHERE you're measuring it.
Obviously the oil in the sump will be colder than the oil which has just run off the bottom of the pistons.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Stealer Of Souls » Thu Nov 06, 2008 9:37 am
Hmm... this leads on to the question of where is the optimal place to measure oil temp?
My sensor is mounted in the sump. I assume this is normal. The guy who mounted it for me said he did the best he could to get the probe to be as far into the oil as possible.
Hmm.. I started to get concerned when I see 100-120... Should I not worry?
'86 AE85.5 Levin
Stealer Of Souls
Postby IH8TEC » Thu Nov 06, 2008 9:55 am
i measure mine after the oil filter and cooler on the return line going back to the block, take my temp pressure and turbo oil feed from same place.
Postby strx7 » Thu Nov 06, 2008 11:40 am
Stealer Of Souls wrote:Hmm.. I started to get concerned when I see 100-120... Should I not worry?
Nope, thats very normal oil temp.
Diff oil in high HP cars in events like Targa, get very hot. I know guys have put oil coolers and external oil pumps on some targa cars to bring down the oil temp and decrease diff wear.
Postby Stealer Of Souls » Thu Nov 06, 2008 11:05 pm
Huh.. well what do ya know... That's always good... guess I don't need a cooler after all then...
'86 AE85.5 Levin
Stealer Of Souls
Postby matt dunn » Thu Nov 06, 2008 11:28 pm
IH8TEC wrote:i measure mine after the oil filter and cooler on the return line going back to the block, take my temp pressure and turbo oil feed from same place.
depends what you want to know.
You know the temp of the oil that is going into the engine,
which is fine,
but they normally go in the sump which would be way hotter,
so you can tell if your overheating the oil as it wrecks it's properties if cooked.
Postby pureadrenalin » Fri Nov 07, 2008 8:09 am
I measure my oil temps in a sandwage device between the stock oil cooler and oil filter on my MR2. I have been running Mobil 1 10/50. I max my oil temp gauge out in less than three laps at taupo (under 6 minutes) at over 300f (150c), so I don’t know what temp they are getting to.
Needless to say, I’m installing an oil cooler and thermostat before the next race.
I will be very happy if my oil temps drop to a max of 120c.
I’m also changing the oil to Castrol edge 10/60. Slightly thicker, as when the oil is that hot the pressure while downshifting is rather low.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together
pureadrenalin
Postby jondee86 » Sat Nov 08, 2008 10:26 am
Taking a return line temp from the oil cooler is like taking a water
temp reading off the hose coming back from the radiator. It is going
to give a "false" reading of the actual operating temp.
If you are trying to safeguard your engine, you would be better off
taking the temp at the inlet to the cooler, and ahead of any thermostatic
diverter.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Flannelman » Fri Nov 14, 2008 8:10 pm
To do that then either use a drill and tap into an oil gallary or undo a plug, or bolt that the factory used to plug up the oil galleries they drilled when machining the block
Flannelman
formerly known as Affroman
Postby piw » Fri Nov 14, 2008 8:14 pm
normally temps are taken in the sump as that is where it is hottest.
www.jeepolog.com/UserFiles/downloads/trooper_manual.pdf
piw
