What's the pressure plate lbs on a ST215 Caldina Clutch?
Postby cat007 » Thu Nov 06, 2008 2:54 pm
As above
Replacing the clutch in a GTT Caldina. Clutch Industries can do a good deal on one that has 25% more clamping pressure than stock - but I' don't know what stock is. If stock's only 1100lbs, I think I'll pass on that as it'll only mean a 1375lbs pressure plate - for example.......
Postby strx7 » Thu Nov 06, 2008 9:54 pm
I read somewhere that the std GT4 pressure plate is 2100, 2200 or 2400lb. I'd imagine the GT-T caldina to be the same
Postby cat007 » Fri Nov 07, 2008 8:13 am
hmmm - well if that's the case - then that'll be fine.....
Picking it up at mid-day
