3S-GTE Spark plugs
3S-GTE Spark plugs
Postby cat007 » Mon Nov 10, 2008 8:07 am
What does everyone recommend?
We were running some sort of overpriced jobbies before - probably what Toyota recommend.
Suggestions?
Postby Al » Mon Nov 10, 2008 9:30 am
Standard Toyota Denso plugs or cheapy NGK BKR6E if standard.
Al
Postby RunningRich » Mon Nov 10, 2008 11:58 am
ND platinums from Toyota are dirt cheap and last forever.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Twolitre » Mon Nov 10, 2008 3:29 pm
If you get NGK plugs get them from STA parts out near the airport, check out their website $3.20 inc gst each for coppers and the rest of their parts are damn cheap too.
Twolitre
Postby Heylin » Tue Nov 11, 2008 1:15 pm
Ive always used NGK BKR7E for the last 5 years and more recently NGK BKR6E
I went slightly colder after upping the boost to 16psi.
I take them out every 8,000 kms and brush them clean, and replace at 16,000
By my math ive spent mabey $200 on plugs over 6 years and 100,000 kms.
Ive never really felt the need to get fancy plugs, and my recent dyno and af readout proves that copper is fine for 190 rwkw, and the motor runs a healthy 11:1 af ratio at maximum power.
Heylin
Heylin
Postby fivebob » Tue Nov 11, 2008 1:59 pm
Heylin wrote:I take them out every 8,000 kms and brush them clean, and replace at 16,000
That's ok on an MR2, but changing plugs in a Caldina GTT is a major PITA because you need to remove the I/C.
Better just to get the standard Toyota long life plugs and forget about them for the next 50-100,000kms, cheaper in the long run ;)
Postby Py7h0n » Wed Nov 12, 2008 7:46 am
You do realise that the 6's are HOTTER than the 7's right?
Oh and for power, coppers can take whatever you chuck at them as long as you get the heat right - I'm running a non-resister version (CDI) of the BKR plug in the 9 heat range for 440wkw, and they cost me $2.90ea .
I love copper plugs :).
Heylin wrote:Ive always used NGK BKR7E for the last 5 years and more recently NGK BKR6E
Py7h0n
Postby Heylin » Wed Nov 12, 2008 12:22 pm
oops yeah, I run 7s :) LOL I got mixed as I went through a period of getting different 6s and 7s
Heylin
Heylin
Postby RunningRich » Wed Nov 12, 2008 7:57 pm
Heylin wrote:By my math ive spent mabey $200 on plugs over 6 years and 100,000 kms.
In around 150,000 kms of GT-Four ownership I think I've bought two sets of platinum plugs. Last set was $11 each from Toyota.
One of the sets that came out of my Celica went into wifey's Mitsi GSR and did another 15000 kms...
The use of copper plugs is not economic in modern engines.
Richard
RunningRich
Postby Al » Thu Nov 13, 2008 8:19 pm
Don't pay $6+ per plug when you can get them for under $3.
Al
Postby ROBODISCO_20v » Sat Nov 22, 2008 11:19 am
Could try some NGK Iriway7's. Can pick them up quite cheap these days off trademe
ROBODISCO_20v
