Heater fan not working on GTT Caldina..
Postby YLDCHK » Mon Nov 10, 2008 9:00 am
My heater fan not working on my GTT caldina......
anyone got any ideas on what it could be?? Its not blowing hot or cold, and then randomly will work....
I had this happen a few years ago on my old wrx sti, and it turned out that I had a split in my radiator and then the radiator blew...
Will check over radiator tonite, but just seeing if anyone else has had this prob before 1st?
Thanks
Annette
:D
YLDCHK
Postby strx7 » Mon Nov 10, 2008 10:04 am
its becoming a common problem in them
Postby YLDCHK » Mon Nov 10, 2008 10:09 am
strx7 wrote:its becoming a common problem in them
It is??
Ive tried searching the forum, but havent come up with anything?
( i could be searching wrong though)??
:?: :oops:
YLDCHK
Postby strx7 » Mon Nov 10, 2008 1:28 pm
pretty sure it'll be the fan motor itself. Mightn't be a commonly talked about thing on here. but at work i've started to get requests for them and have heard/seen others looking for them
Postby YLDCHK » Mon Nov 10, 2008 4:29 pm
could it be electrical, like a fuse or faulty connection or somthing, since it goes randomly'??
YLDCHK
Postby MrOizo » Mon Nov 10, 2008 4:38 pm
could be something like a dry solder on a control module dont it? the resistors on the older toyotas always stuff out - not the same case is it?
MrOizo
Toyspeed Legend
