MASTER CYLINDER UPGRADE
Postby ke_25 » Mon Dec 01, 2008 8:43 pm
hey, i have ke35 and have upgraded brakes to vr4 rears and wilwood 4 pots on the front, was wondering if its worth wile/necessary to upgrade the master cylinder?
or can i get away with teh factory new ke30 or what will happen, i have read that a early 90s pajero one wil bolt up and fit with later ports, but is this necessary is my question, not really sure what its achieving
cheers shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby frost » Mon Dec 01, 2008 9:14 pm
to move four pots yea you will need bigger master, skyline gtst master is a bolt on mod for ae86 masters and im sure there the same for ke (i could be wrong i never seen a ke30 master.
Postby thegreatestben » Mon Dec 01, 2008 9:17 pm
New brakes will probably displace some more fluid.
Can always adjust the throw of the pedal to suit once you change it.
thegreatestben
