anyone run rear swaybaron ke3# before?
Postby ke_25 » Tue Dec 02, 2008 10:42 am
went to put on rear swaybar on the sr coupe yesterday, and it doesnt fit. i am running hilux diff so i have modified different u bolts and sway bar mounts to comply with the lager OD diff, but the swaybar seems to hit the shocks in the rear, i think this may be due to running lowering blocks so lifting the diff up higher from the point where the shocks are mounted,
floor is yet to be cut up so unsure what suze blocks will be running
was wondering if anyone has come into teh same complication before?
swaybar kit is whiteline
cheers shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby repowered » Tue Dec 02, 2008 11:56 am
yea i ve heard of these from whiteline! will be interested to see how you get on. Have you got the front one as well?
Rollin!
repowered
Postby ke_25 » Tue Dec 02, 2008 6:13 pm
yeah ive instaled teh larger 22mm font one, rhey actually supply selbys ow but is same as whiteline. the rear isnt fitting up due to i think you may not be abl to run blocks with these, wil let you know how i get on,
any one else has these issues?
ke_25
Postby repowered » Wed Dec 03, 2008 2:39 pm
Yea will proabably be because of the lowering blocks aye. You might have to look at getting a custom bar made up at a spring makers or somthing? that would probably be pricey though?
do you know how much different that front swaybar made? or is she not on the road yet? did it come with bushes?
whats selbys?
Rollin!
repowered
Postby ke_25 » Wed Dec 03, 2008 7:57 pm
i went thorugh SAS which now do selbys aswell, i think its exactly teh same except one is yellow and one is silver, i got it re cated, my fornt was a 22mm selbys. yeah could be to do with the blocks i yhink, i could mount it down lower but dotn think it would be the most attractive set up,
yeah i got these at a good price
and yes comes complete with all, bushes and everything. although alot of bushes i re purchased so they were all nolethene red, not yellow. being picky.
ke_25
