trd diff-oil
trd diff-oil
Postby groupagt4 » Sat Dec 06, 2008 11:08 pm
Searched but couldnt find. Which oil should i use in my trd 2way lsd(ae86) something i could buy from repco preferrably
groupagt4
Postby trd_chik » Sat Dec 06, 2008 11:16 pm
if u ring up repco they should be able to tell u either through the computer catalogue system or by looking it up in the lube manuals
trd_chik
Postby Mr Revhead » Sun Dec 07, 2008 12:03 am
i doubt a TRD LSD is on the repco system
have a look here for the specs.
get something that matchs those specs. which i think you wil find is covered by most decent LSD oils
Postby Burning Angel » Sun Dec 07, 2008 8:24 am
the only stuff repco keeps in stock normally is Castrol LSX90 & Valvoline LS90.
both have the friction modifiers need for clutch type lsd's
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Elmendorf » Sun Dec 07, 2008 3:43 pm
I don't run friction modifier with my TRD LSD use Redline oil however.
Elmendorf
Postby Celica RA45 » Sun Dec 07, 2008 4:36 pm
try penrite 90 -140 lsd oil normaly in 2 litre containers
Celica RA45
Re: trd diff-oil
Postby allencr » Sat Dec 13, 2008 7:49 am
groupagt4 wrote:Searched but couldnt find. Which oil
It's hard to find a lube that isn't good/OK for your stuff, hypoid gears with a clutch plate type LSD.
Don't buy anything that is only advertised as 'gear oil' and not hypoid.
Don't buy anything that doesn't claim to be OK for an LSD and have spec GL-3 4 5 whatever.
Then, if it chatters judders makes noise when making tight turns, a friction modifier additive might make it better.
The viscosity's mostly dependent on your local climate and whether you're pulling a trailer or racing, IMO lower/lighter is better for auto-xdriftinggymkana, short length low heat stuff even the Autoban, if it isn't badly worn.
allencr
Postby MrDori » Sun Dec 14, 2008 11:17 am
redline is what i use in my cusco 2way, still chatters abit, but generally pretty good, just cant give it any gas when doing tight turns or it skips
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
