What are GOOD A/F Ratios ??
Postby jondee86 » Sun Jan 04, 2009 3:06 pm
Just fired up my LC-1 Wide Band Controller and A/F gauge. Took the
car for a short run to see what sort of numbers I was getting...
12.5 @ WOT
14's and 15's @ just driving around
13.3 @ idle (you can see the off throttle idle enrichment working :) )
Just curious to know if these are good numbers ??
I'm running a simulated narrow band output to the stock ECU. Will go
to direct wide band data out to the aftermarket ECU when it gets installed.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby IH8TEC » Sun Jan 04, 2009 3:49 pm
seems pretty good to me, i'm assuming this is NA? cause turbo i'd want a bit richer on WOT and boost.
Postby Lith » Mon Jan 05, 2009 2:26 pm
Yeah they sound pretty ideal for an NA setup :)
2007 Mazdaspeed Axela
Lith
Postby jondee86 » Mon Jan 05, 2009 5:57 pm
Sweet :) The instructions have a bunch of stuff saying that your readings
can be off if you have bad earths. So I wanted to check that I was in the
ballpark with the actual readings.
Yeah... NA for sure, and the stock smallport ECU doing a good job taking
care of a little bit of extra air from mild cams and poddy intake :)
Cheers... jondee86
jondee86
Postby strx7 » Tue Jan 06, 2009 6:48 am
12.5:1 seems a bit rich for an n/a but in saying that all motors are different, and some prefer to be a bit richer while other prefer to be a bit leaner, somewhere between 12.7:1 and 14.0:1 is what most n/a should be at WOT
Postby jondee86 » Tue Jan 06, 2009 9:35 pm
Just found this on another forum tonight...
This is from "How to Tune and Modify Engine Management Systems"
by Jeff Hartman
Air/fuel Mixture and Characteristics
AFR Comments
6:0 Rich burn limit (fully warm engine)
9:0 Black smoke/low power
11.5 Approximate rich best torque at wide-open-throttle
12.2 Safe best power at wide-open-throttle
13.3 Approximate lean best torque
14.6 Stoichiometric AFR(chemically ideal)
15.5 Lean Cruise
16.5 Usual best economy
18.0 Carbureted lean burn limit
22+ EEC/EFI Lean Burn Limit.
As said, seems to indicate there is a bit of latitude on the AFR's
according to what you are tuning for. Factory tune will be on the
conservative side to cater for shopping basket use.
Cheers... jondee86
jondee86
